Whistle in Engine Bay
Hello,
I have an 08 Express 3500 cutaway (mini bus) 4.8L with 41,XXX miles on it. I'm hearing a whistle nosie when I let off the throttle above 35mph. The noise goes away when the throttle is pushed or the trans is shifted from Drive to a lower gear. It sounds like it's coming from the passenger side but hard to tell when driving.
check for vacuum leaks
Vacuum leak in the passenger footwell area would likely be the HVAC controls.
HVAC position doesn't matter. Vacuum is present anytime the engine is running.
123indyrt
May 24th, 2022 8:11 PM
shawner73
February 1st, 2022 3:21 AM
dbeason
April 25th, 2010 5:10 PM
