Whistle in Engine Bay
Old Oct 29, 2022 | 11:19 AM
Trailsofdanindy's Avatar
Default Whistle in Engine Bay
Hello,
I have an 08 Express 3500 cutaway (mini bus) 4.8L with 41,XXX miles on it. I'm hearing a whistle nosie when I let off the throttle above 35mph. The noise goes away when the throttle is pushed or the trans is shifted from Drive to a lower gear. It sounds like it's coming from the passenger side but hard to tell when driving.
Old Oct 29, 2022 | 11:33 AM
check for vacuum leaks
Old Oct 29, 2022 | 11:35 AM
I haven't seen anything yet but will definitely go over it again. There also aren't any codes set.
Old Oct 29, 2022 | 12:23 PM
Triaged's Avatar
Vacuum leak in the passenger footwell area would likely be the HVAC controls.
Old Oct 29, 2022 | 12:42 PM
With the HVAC in the off position, it still makes the whistle noise.
Old Oct 29, 2022 | 1:49 PM
HVAC position doesn't matter. Vacuum is present anytime the engine is running.
123indyrt
May 24, 2022 8:11 PM
shawner73
Feb 1, 2022 3:21 AM
dbeason
Apr 25, 2010 5:10 PM
ksmith40
Sep 18, 2007 11:36 PM
camelflage
Jan 15, 2007 7:37 PM
