wire or fuse to splice to make anti theft fuel pump cut off ?
Old Jul 8, 2021 | 6:47 AM
  #11
Gumby22's Avatar
I wouldn’t recommend just tapping into a fuse slot - if the thieves in your area have been somehow bypassing the pass lock system, a couple of wires running out of the fuse box would be pretty easy to remove and the fuse terminals jumped to get it started.
The fuel pump is powered by a gray wire - I’d tap into the harness running along the frame rail and fish the wires for the switch into the cab. They’ll be much less exposed and harder to spot and you could hide the switch from view.
Old Aug 19, 2021 | 7:15 PM
  #12
Trackvw's Avatar
Your van's VTD system already disables the fuel injection system. The only way to disable security is for the correct key to be sensed. Punching the lock won't disable it, and forcing the cylinder to rotate won't disable it either. Doing this will only trip the tamper switches. If the thief is skilled and equipped enough to know how to bypass a Passlock system, then he's not going to be stopped by a fuse.
my 2005 van was stolen a couple weeks ago,
they used some kind of key to start it and disable the steering lock,
VTD did not save it , but I had a tracker in it and that found its location about a mile away .
another exciting afternoon !
Old Aug 21, 2021 | 12:43 PM
  #13
pomerlo's Avatar
What about using
this this
or/and
this this
It would force a thieft to make some noise if the van sit in the driveway overnight.
My guess is when they see such devices they wont bother.
Old Aug 21, 2021 | 1:15 PM
  #14
Trackvw's Avatar
thanks for your suggestions , I have a big chain locked from seat bracket around the steering wheel, with a big lock.
a Club would help too.
I also have a wheel lock that I use on my car trailer, as it sits most of the time. It would be a hassle to install/remove many times a day.
Anyway please keep the ideas coming for all of us !
Old Aug 21, 2021 | 1:21 PM
  #15
move to a better neighborhood
Dylan Meyer
1988 - 1998 (GMT400)
Jan 10, 2017 4:27 PM
halfton1500
Jan 15, 2014 6:59 AM
Eric's S-10
Jan 25, 2012 7:24 PM
clwill65
Astro
May 15, 2008 4:53 PM
TDC697
Oct 16, 2007 5:07 PM
