Wire loom for side door door jamb?
Anyone ever get a wire loom in here? What wire loom did you use and how did you get it mounted?
From the factory, the doors use a strike plate for the power locks. I got the strike plate from the junkyard, but my aftermarket power lock kit only works if the door is closed.
I also am hoping to add some more electrical widgets to the door, so if I could get a wire loom in there, that would be ideal.
With the door closed, there's about a pinky worth of room between the door and the door jamb
Side door.
I found something on amazon:
Works OK, but sometimes gets hung up if you close the door too quickly.
jamesm113 (August 4th, 2022)
Side door.
I found something on amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
