Wire loom for side door door jamb?
Old May 10, 2022 | 6:24 PM
jamesm113's Avatar
Default Wire loom for side door door jamb?
Anyone ever get a wire loom in here? What wire loom did you use and how did you get it mounted?
From the factory, the doors use a strike plate for the power locks. I got the strike plate from the junkyard, but my aftermarket power lock kit only works if the door is closed.
I also am hoping to add some more electrical widgets to the door, so if I could get a wire loom in there, that would be ideal.
With the door closed, there's about a pinky worth of room between the door and the door jamb
Old Aug 3, 2022 | 6:03 PM
Edward Andriaccio's Avatar
is this the rear door or the side door?
Old Aug 3, 2022 | 6:06 PM
jamesm113's Avatar
Side door.
I found something on amazon:
Amazon Amazon
Works OK, but sometimes gets hung up if you close the door too quickly.
Old Aug 4, 2022 | 3:36 AM
William Kisselstein's Avatar
The factory one only works when the door is closed, too.
Old Aug 4, 2022 | 10:25 AM
is there a part number for that strike plate?i cant find it on gm parts website
Old Aug 5, 2022 | 6:47 PM
Trailrez1's Avatar
Side door.
I found something on amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
If it we’re mine, I might make door side hole bigger, and get some kind of spring tension on it.
jamesm113
Aug 30, 2021 1:33 PM
johnnythunder
Aug 3, 2019 6:47 PM
tawas23
Mar 17, 2016 2:58 PM
dillon1001
Jan 7, 2015 10:39 AM
Susan Gautam
Jun 25, 2012 11:26 AM
