Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
Backfiring or burping through carb
Old Mar 9, 2021 | 8:56 AM
85s10's Avatar
Default Backfiring or burping through carb
Hey there chevy peeps, so i got a sbc 307- and im having issues with it burping back through the carb, i have a gear drive in t and timing is on, just did a carb rebuild , its a holley 1850, cant get it figured out.. any help would be appreciated
Thanks
Old Mar 10, 2021 | 6:39 AM
85s10's Avatar
No love huh people, maybe i joined wrong forum
Old Mar 10, 2021 | 7:29 AM
kevinkpk's Avatar
Well, it has been 9 1/2 hours since you posted last night. First, you're posting in the wrong section, and people that can help, are not seeing your post. Back firing through the carb is timing. Is this a point or electronic distributor? Make sure you are on #1 TDC, Follow the firing order on the distributor cap, to each cylinder, go from there.
Old Mar 10, 2021 | 7:50 AM
85s10's Avatar
timing is set and its electronic distributor it trys to start but it takes alot longer than it should to fire, then its not really a backfire its more like a burp
Old Mar 10, 2021 | 7:51 AM
85s10's Avatar
where is the right place to get help here
Old Mar 10, 2021 | 9:22 AM
kevinkpk's Avatar
Post what vehicle you have under that section.
Old Mar 10, 2021 | 9:25 AM
kevinkpk's Avatar
Recheck your timing, and look at the spark, is it white, red? If you are confident of the ignition, then move on to the carb. If you can post a little more information, that would help. I.E new carb, new ignition, was running, replaced timing chain etc.
Old Mar 10, 2021 | 9:51 AM
85s10's Avatar
pretty confident with timing , rebuilt holly 1850 but just picked up a edelbrock , it has a gear drive in it and it was running, then i switched intake over to edelbrock and been ****ty ever since
Old Mar 10, 2021 | 9:54 AM
85s10's Avatar
85-s10
Old Mar 10, 2021 | 9:55 AM
Welcome to the forum.
Like Kevin said, it would be helpful if we knew the recent history on what is been going on. The only other thing I could think of would be the plug wires themselves.
A number of years ago I was helping troubleshoot a similar problem and didn't know the recent history. Turned out that he just washed the engine compartment the day before. The problem would have been easy to solve had I known that at the beginning. 😎
