Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
Backfiring or burping through carb
Old Mar 10, 2021 | 12:47 PM
  #11
kevinkpk's Avatar
Originally Posted by 85s10
pretty confident with timing , rebuilt holly 1850 but just picked up a edelbrock , it has a gear drive in it and it was running, then i switched intake over to edelbrock and been ****ty ever since
Too me it seems like with what I understand (post a video, or audio of the "burp") given everything else (as suggested plug wires, are they carbon, solid wire, age?) It wouldn't be a big issue to pull the intake, check for leaks, also the carb. I've had probably 2 dozen leaking carb base gaskets in my past.
Old Mar 10, 2021 | 9:07 PM
  #12
85s10's Avatar
The plug wires are brand new think they are carbon and new base gaskets. You talking about leaks in the intake? And now i lost spark to the damn thing. Getting pretty frustrated with it, the motor itself me and my partner we tore it down hoaned it new Rod bearings,pistons rings lifters ect. Havent got the damn thing to run long enough to dial anything in, “ im pretty sure i messed up when putting pistons in and used assebly lube, its hard to turn engine over by hand with no plugs- should i pull pistons back out and just use motor oil- hetting ready to throw in the towel im so frustrated
​​​​​​ Thanks guys for input
Old Mar 11, 2021 | 6:58 AM
  #13
kevinkpk's Avatar
You should be able to turn it with resistance plugs out. You did use assymbley lube, and oil on the rings?
Old Mar 24, 2021 | 7:22 PM
  #14
85s10's Avatar
Default Update on issue
85-s10
Originally Posted by 73shark
Welcome to the forum.
Like Kevin said, it would be helpful if we knew the recent history on what is been going on. The only other thing I could think of would be the plug wires themselves.
A number of years ago I was helping troubleshoot a similar problem and didn't know the recent history. Turned out that he just washed the engine compartment the day before. The problem would have been easy to solve had I known that at the beginning. 😎
so i decided to pull motor back out and tear back down, I’m glad i did had two pistons on each side in backwards, and when i drained oil was lots of gas in oil, got engine almost ready to fire up.. gotta finish my homemade engine cradle, so i can dial it in before i stab it back in ...!! I’ll post pictures when cradle when complete
Old Mar 25, 2021 | 2:47 PM
  #15
Will like to see what you come up with as I've been thinking about doing the same thing.
Robs468
Jan 28, 2021 2:21 AM
Slapee
Aug 30, 2016 3:06 PM
March17green
Aug 10, 2016 7:14 PM
jkann1
Jun 29, 2010 1:12 PM
Dubya
Oct 14, 2006 11:57 AM
