Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
stumped
Old Sep 18, 2013 | 5:42 PM
sheldon1970's Avatar
Default stumped
I have a 2006 z71 the motor blew it had a 5.3 I put a used low mile 4.8 in it. It will turn over but not getting any fire
Old Oct 13, 2013 | 7:55 PM
65duce2dr's Avatar
Hi Stumped
You need to double check all your work & make sure all electrical connection's are connected & all are good clean & dry , also you may want to separate them & check for bent terminals therefoer causing a bad connection ,, also most importantly make sure all your grounds are connected & tight. If you have use of a scanner & can check for codes which may steer you in direction and if the you can perform a data stream test while cranking the engine you can see if all sensors are reading and if they are operating within there designed parameters.
frickenbored
K5 Blazer
Sep 5, 2009 11:37 AM
drphilgood01
Jun 15, 2009 1:10 AM
Sevens
Jan 29, 2009 10:06 AM
kirah825
Dec 29, 2008 6:52 PM
FreakOut420
Apr 22, 2006 4:18 PM
