03 2500hd with no crank issue
Old Jan 4, 2009 | 5:45 PM
chris694205's Avatar
Default 03 2500hd with no crank issue
hello all i am a new to the site and am having problems with my 03 2500hd with the 8.1/allison. last week i turned the key and all the lights and guages came on... but wheni proceeded to start the truck i got nothing.. so i crawled underneath and jumped the selenoid and it started right up.. so i took it to my buddies shop and he replaced the starter and selenoid and the starter switch and that did absolutely nothing...
right now i am turning the key on and going under the hood and jumping the starter relay in order to start it..
Does anyone have any ideas
Old Jan 4, 2009 | 7:18 PM
Bandit21's Avatar
Default RE: 03 2500hd with no crank issue
hey check to see if the start relay under the hood should be on the driver side is good
Old Jan 4, 2009 | 10:05 PM
MDTAHOE's Avatar
Professional Mechanic
Bad or loose battery cable bolts can cause the exact same syptoms as a bad starter. If they are tight remove them from the battery and look at the cable where it touches the battery. Also inspect the threads.
Old Jan 5, 2009 | 6:17 PM
well guys its fixed... the connectors to the nsbu switch on the allison were bad... thanks for the help
turbodremz
May 5, 2025 1:17 PM
camarozracer8
11
Feb 1, 2014 8:03 AM
SyberTiger
Aug 26, 2013 12:50 PM
gslim
May 23, 2012 7:51 PM
gregh.ny
10
Jul 22, 2009 6:54 AM
