03 suburban 1500 2WD drive shaft
Old Jun 18, 2020 | 1:47 PM
MrAxtell69's Avatar
Default 03 suburban 1500 2WD drive shaft
So I am needing to know if when I put the drive shaft back in my suburban, is there any certain way that it needs to line up? My U joint went out on the back end of it and dropped it to the ground. So nothing was marked on were it was at. Got the u joint in but can't find any information on if there is a certain way that it has to be put back in.
Old Jun 18, 2020 | 3:31 PM
Little Bear's Avatar
No it doesn't matter, but if the shaft dropped while driving there is a chance that may have bent a bit. If you have a vibration that you didn't have before it dropped you may want to have it checked out at a drive shaft shop.
Old Jun 19, 2020 | 4:58 AM
oilcanhenry's Avatar
I've seen new vehicles with out of balanced driveshafts. Yeah, get that DL into a shop!
Old Jun 19, 2020 | 6:32 PM
Dragnfyr's Avatar
Lightbulb Drive shaft
If I recall correctly, the driveshaft can be reinstalled so long as you line up the rear yoke and the the u-joint. I need to say that I am not a professional in any way. I am just a guy who is mechanically inclined. The Best suggestion that I can give overall is to pickup a Haynes manual (or any of the other types of self help books on your vehicle) from your local parts store or on-line and it will tell you for sure.
Drag
Jwnicholson
2007 - 2013 (GMT900)
Aug 12, 2019 7:49 AM
Jonnydun
Jan 13, 2018 1:35 PM
RitualJman
Jun 5, 2013 10:21 AM
socplay50
Jul 10, 2012 10:00 PM
cummins rules
Feb 27, 2012 8:26 AM
