04 Trailblazer bad ac smell
Old Jan 27, 2009 | 11:04 AM
Sweetbabe's Avatar
Unhappy 04 Trailblazer bad ac smell
I need help, i have a 04 Trailblazer LS with a smelly ac, everytime I turn the ac a mold smell comes out, it only last a few minutes after that it doesn't smell bad anymore unless i"m used to the smell.
Please help
Old Jan 28, 2009 | 8:08 AM
It is mold you smell and it’s probably built up on the AC coil and or in the outside air intake.
Check and make sure the drain port for the AC is not plugged (ever had a wet floor on the passenger side, that’s caused by the blocked drain over flowing inside the passenger compartment)
The same holds true for the outside air intake, the area below the windshield is typically where air is pulled into the passenger compartment, if the drain(s) for that area are blocked the water stagnates and starts stinking.
Find the drain points for those areas and clear them, then flush the area below the windshield with plenty of clean water and maybe some mild soap to help clean out the areas that cant be reached by hand.
There is also the possibility that water has gotten into the blower housing and is stagnate, remove the blower motor and inspect the area for water, leaves, bugs….
Old Jan 28, 2009 | 11:41 AM
Sweetbabe's Avatar
Thumbs up Thank you
Hello, I'll try that and see what happens, now that you mentioned it, my car doesn't drip any water from the passenger car like other cars.
Thank you again
VPasculli
Feb 18, 2013 1:01 AM
bavant
Jan 16, 2012 2:12 PM
LatitudeDancer
Jun 3, 2011 1:06 PM
Sweetbabe
Jan 27, 2009 1:25 PM
clowninxs
Mar 7, 2007 8:18 PM
