1976 350 engine swap to a 89 350 engine
Old Oct 17, 2018 | 6:03 PM
  #11
Chris Call's Avatar
I read that the later engines had different flywheel bolt patterns and a one piece rear main seal.
Old Oct 17, 2018 | 6:33 PM
  #12
geo1's Avatar
I think,one piece rear main seal goes back to 87?about when roller cams were introduced, bell housing the same,ls motors we're the change,now you got me checking
Old Oct 17, 2018 | 6:43 PM
  #13
geo1's Avatar
Yep,you are correct,86 newer,needs the flywheel to match,crank bolt holes changed,not ring gear
Old Oct 17, 2018 | 6:51 PM
  #14
Chris Call's Avatar
Found this video. https://youtu.be/Y91ut0D0wGo
Old Oct 17, 2018 | 6:56 PM
  #15
geo1's Avatar
What's it say,any hidden problems?
Old Oct 17, 2018 | 7:01 PM
  #16
Chris Call's Avatar
Says the exhaust manifolds are slightly different and require the newer ones, the intake is very different, the flexplate ID is smaller, but other than that, it bolts up to a 350 trans right and motor mounts are right. My old 350 has headers which are going in the bone pile anyway and apparently all the old bracketry will work as well.
Old Oct 17, 2018 | 7:02 PM
  #17
Chris Call's Avatar
I will definitely be going with the Vortec.
Old Oct 17, 2018 | 7:07 PM
  #18
geo1's Avatar
Yep,so some parts stay with donor motor,I think tbi is better for a truck,more low end torque then the dreaded spider,I made it a minute into video,started to yawn,what was next,how to make coffee?
Old Oct 17, 2018 | 7:48 PM
  #19
Chris Call's Avatar
Definetly a long yawny video and some of the work was sketchy, but the tidbits were there.
Old Oct 17, 2018 | 7:52 PM
  #20
geo1's Avatar
So,no reason to not do it,with tbi on top,vortec base, maybe 300 or slightly less h.p.,totally stock,not bad
