1990 Silverado fuel gauge reads wrong all the time
Old May 13, 2011 | 4:15 PM
cb1234wp's Avatar
Default 1990 Silverado fuel gauge reads wrong all the time
1990 P/U just recently started this. It shows almost full of gas even though I only put in about 5-6 gallons. How hard is it to replace, or reset the fuel sensor?? Or is this something that just needs to be replaced??
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
Last edited by cb1234wp; May 14, 2011 at 10:02 AM. Reason: cause i worded it incorrectly
Old May 16, 2011 | 4:21 PM
Canadian Cowboy's Avatar
Does the gauge move at all? if you disconnect the wiring harness at the fuel tank with the key on the gauge bar should move,if it does mostly the sender in the tank is toast.
One to check is to ground the sender wire to the frame the bar on the gauge should read past full,when not grounded it should read zero,if it does for sure the sender in the tank is shot.
CC Name:  sfachevy.gif
bosanci28
Oct 22, 2019 11:10 AM
eltatertoto
Feb 19, 2014 12:28 PM
Brother Tolduso
Dec 21, 2012 3:14 PM
Matt90lx
Cobalt
Mar 7, 2011 6:57 PM
sgothard
Apr 10, 2007 12:32 AM
