1996 lumina ran it out of gas now will not start
Old May 17, 2010 | 11:38 AM
chevy_smoken's Avatar
Default 1996 lumina ran it out of gas now will not start
I ran my 1996 lumina out of gas, I have put gas in it but it will not start, i can saturate a cloth and put in the intake and it will start. After that gas is burned up the car dies. it is V-6 fuel injected!
thank you
Old May 17, 2010 | 5:35 PM
desrtrat's Avatar
how much gas did you put in the tank..
Old May 17, 2010 | 8:15 PM
MDTAHOE's Avatar
Professional Mechanic
Fuel pump may have burned up or the filter maybe restricted.
Old May 18, 2010 | 7:19 AM
i have put about 5 or 6 gallons of gas in the fuel tank. Car still will not pick up the gas. Checked all fuses yesterday afternoon. How can I check the fuel pump and where is it located?
thanks for your time
Old May 18, 2010 | 7:02 PM
desrtrat's Avatar
that should be enough to pick up, some people just don't put enough in the tank...check if there is a fuel pump relay. you can swap it out with the AC relay to check if good. the pump is in the tank i believe..
good luck
LippinOff
Dec 23, 2020 5:13 PM
caddieb
May 15, 2011 5:32 PM
truthstar
Jul 8, 2010 4:28 AM
dand1966
Uplander
Aug 31, 2009 3:54 PM
sbbrown
Mar 3, 2007 9:16 PM
