2000 4l60E issue NEED HELP
Old Jul 30, 2018 | 6:01 PM
justin kitelinger's Avatar
Default 2000 4l60E issue NEED HELP
I NEED HELP! I have a 2000 Silverado z71 4x4 5.3. I took the bad 4l60 out and I have a donor truck exactly the same that I drove to the garage that shifted perfectly. So I put the transmission in mine changed the fluid and now it won't move. If I redline it, it will creep forward a little. I don't get it worked perfectly in the other truck. I've checked all the connections. Any advice would be greatly appreciated
Old Jul 30, 2018 | 11:34 PM
oilcanhenry's Avatar
Assuming everything is hooked up and wired, its likely a pump or torque converter issue.
