2002 Chevy Cavalier overheating?`
The little 2002 Chevy with the 4 cyl. engine (40,000 miles) has developed a coolant/overheating problem, and I'm wondering if someone on here might offer a suggestion or two as to what is wrong and what might be done to fix it?
The car started running hot all of a sudden. Couldn't seem to find a reason for it at first. Later got to where it wouldn't start at all. Took out a couple of sparkplugs and turned it over. Coolant sprayed out of the spark plug holes!! Is it head gasket? Intake gasket? Or what??
ThanksI appreciate your time
im fairly sure that would be your head gasket. is it under warranty? hope it is. that sucks. that happened to my buddys 92 explorer. yet it still ran. never hydro locked and one cylinder was half full when we took the head off. coolant poured out like nuts when we removed plugs. if and when you get that bad boy fixed, change the oil as well. my buddy found some lovely froth in the head from coolant and oil combination and well changing the oil eliminates any possible further damage of coolant being where it shouldnt.
Sounds like your thermostat stuck and you didn't notice it in time. I agree with the blown head gasket. Not a real tough job, but after putting it back together, I'd run a can of engine flush through it and change the oil and filter.
