2002 Suburban No DRL's. Help?
Wife and I heard a beep in 2002 Suburban. Looked around saw nothing. Laughed about it. Well, not funny now. No DRL's. I checked relay, good. Checked fuse, good. Checked bulbs, good. Wtf? lol. DRL module? If so, where is it at and what's the model number?
Thanks
Thanks
I have a 99 which is very much like the 2002 and when I had problems with my DRL's it was the socket the bulb plugs into. There is much heat from these lights and that damaged the socket causing it not to make a good connection. Might not be your problem but is worth a try.
No DRL, and only headlights come one instead of DRL in day light and night. So, headlights are always on now. I assume something senses that there is no DRL and the regular headlights come on?
I have a 2002 Suburban and recently found a blown DRL, I noticed the bulb holder was scorched due to the constant heat from the bulb, so I replaced both with the equivalent LED, I little bit brighter and no heat, straight swap. Hope this helps.
Gus UK
Gus UK
lewijo
Aug 11, 2015 9:53 PM
