2002 Suburban No DRL's. Help?
Old Dec 14, 2012 | 7:02 PM
Suburban7081's Avatar
Default 2002 Suburban No DRL's. Help?
Wife and I heard a beep in 2002 Suburban. Looked around saw nothing. Laughed about it. Well, not funny now. No DRL's. I checked relay, good. Checked fuse, good. Checked bulbs, good. Wtf? lol. DRL module? If so, where is it at and what's the model number?
Thanks
Old Dec 15, 2012 | 11:26 AM
I have a 99 which is very much like the 2002 and when I had problems with my DRL's it was the socket the bulb plugs into. There is much heat from these lights and that damaged the socket causing it not to make a good connection. Might not be your problem but is worth a try.
Old Dec 15, 2012 | 12:19 PM
Yes, they look burnt.
No DRL, and only headlights come one instead of DRL in day light and night. So, headlights are always on now. I assume something senses that there is no DRL and the regular headlights come on?
Old Dec 15, 2012 | 1:00 PM
New dash mat made the lights come on always. Going to fix that tonight. Going to get some new DRL bulbs and I will post back.
Old Dec 15, 2012 | 1:13 PM
Gustheiceman's Avatar
I have a 2002 Suburban and recently found a blown DRL, I noticed the bulb holder was scorched due to the constant heat from the bulb, so I replaced both with the equivalent LED, I little bit brighter and no heat, straight swap. Hope this helps.
Gus UK
lewijo
Aug 11, 2015 9:53 PM
bud1tig2
Jul 14, 2011 7:45 PM
thetahoe
Nov 5, 2008 2:27 PM
ussva
Oct 4, 2007 8:05 PM
peterj
Mar 31, 2007 3:35 PM
