2007 Impala Transmission Whine
I owe a 2007 Impala with 69000 miles. Normally while driving around town there is no transmission whine or problem. But when I have a long deceleration such as coming off an expressway ramp to a complete stop and then accelerating a low level whine occurs in the transmission. It is more prevalent when I shift into 3rd or 2nd descending a steep grade and come to a complete stop at the foot of the hill. NO WHINE while descending but as soon as I accelerate from stop at foot of hill the whine occurs till it shifts into 2nd or 3rd.
Fluid level is correct and appears pink and smells OK.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Deano849,
Answered in the Impala thread.
Louis
GM Customer Service
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Deano849,Answered in the Impala thread.
Louis
GM Customer Service
I siphoned off 7 qts (about 1/2 of all) of transmission fluid and replaced it with new fluid. Noise immediately disappeared and hasn't returned after 7 months and 10000 miles.
Use a small plastic hose in the transmission dip stick port. Or completely change all fluid
by removing pan. Good luck
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Chantele Mallett,I am sorry you are experiencing this issue with your Impala vehicle. I encourage you to consult with a certified technician for additional assistance. They should be able to offer additional information after inspecting the vehicle.
Please keep us posted.
Louis
GM Customer Service
Ok, took me a while,but, the whining noise may be your power steering pump. Try starting car, make fluid lever is good, put in neutral(apply parking brake😄
,then turn steering wheel all the way right n left, hold for about 5-10 seconds while increasing eng. rpm just a bit. Try it. If that doesn't work, you made need some money to fix the problem, now, you can panic...😄good luck!
randyehughes
Jun 7, 2006 5:56 PM
