2008 Impala reduced engine power ....but no change in engine performance
Old Sep 26, 2025 | 5:16 PM
Tlnurse66's Avatar
Default 2008 Impala reduced engine power ....but no change in engine performance
2008 Chevy Impala LS check engine, abs, service traction, and reduced engine power while driving but speed wasn't affected. Maintained 60 mph with no surging or fluctuating rpms....car drives fine
Old Sep 29, 2025 | 11:06 AM
Hulk40187's Avatar
Codes??
Old Sep 29, 2025 | 2:12 PM
Grumpy 150's Avatar
I had the same with my 2009 Impala. It would come and go. It was caused by the throttle position sensor, bad solder joint in there.. Requires replacement of the accelerator pedal.
Old Oct 2, 2025 | 1:11 AM
Tlnurse66's Avatar
Default Accelerator pedal position sensor
I replaced the accelerator pedal today . So far that code is gone but still seeing one for camshaft position sensor and it was changed a month or so ago. ABS and service traction lites still on. Pretty sure it's the wheel speed sensor on passenger front. Checking it tomorrow thanks for responding
Old Oct 2, 2025 | 9:24 AM
Grumpy 150's Avatar
Did you clear the codes after installing the pedal?
Old Nov 4, 2025 | 3:14 PM
cortezjc0001@gmail.com's Avatar
Did you ever resolve this?
jmcoulter85@verizon.net
May 4, 2021 2:07 PM
LaurensSilverado
2007 - 2013 (GMT900)
Apr 13, 2019 1:31 AM
smaerdym
Aug 12, 2018 10:54 PM
Ramiro1214
Apr 6, 2018 11:35 AM
Skelly1124
Jul 11, 2016 9:03 AM
