2009 Suburban P0452 CODE
Old Mar 6, 2022 | 2:15 PM
Ang1972's Avatar
Default 2009 Suburban P0452 CODE
This code keeps coming up on my truck. 2009 suburban LT. 5.3 FLEX. Just basic research showed its a fuel tank pressure sensor located on top of tank attached to the pump assembly. As luck would have it, I needed to change my fuel pump anyway. I dropped the tank and replaced the pump. The new pump already has a new fuel pressure sensor..so all good there. Put it all back together, drove it a couple of miles, and the code came back. P0452.
Any thoughts on what to check? Truck runs fine aside from that. No rough idle. No gas leak or smell of gas.
Old Mar 6, 2022 | 5:29 PM
. unplug the connector and key to run...if the code goes to circuit high the fault is most likely in the new sensor. if the code stays circuilt low...either the wiring is shorted to grd or the pcm is bad. ohm check the wiring...unplug from pcm...check continuity and short to power and grd. if ok...suspect pcm.
Joshua Jensen
Jul 17, 2020 2:08 AM
willyd
Aug 26, 2013 5:25 AM
hig
Jul 1, 2013 5:26 PM
camotruck55
Dec 15, 2011 1:53 AM
don tyler
Mar 11, 2010 1:00 PM
