2016 Tahoe LT Throwing MAJOR Codes
Old Jul 9, 2023 | 6:12 PM
bpolak's Avatar
Exclamation 2016 Tahoe LT Throwing MAJOR Codes
I was in the process of going to the market, my Tahoe was running fine and showing no signs of struggels. I cam out and attempted to start and my truck decided that it was not going to start. It had service engine lights on, telling me to service the 4wd trailer brake, traction control and power steering, Then told me that the engine power had been reduced. Upon checking it looks like i lost connection with ECM, TCM, Can Bus Communication, TCM Requested MIL Illumination. Codes are as follows, U0101,U0100 (Stored), U0073 (Permanent), U0101 (Permanent),U0101 (Pending). I am unsure what to do, truck is sitting at the shop until at least tomorrow but nothing was wrong with it, it was running fine. Has anyone else had this issue before and what did they do to fic?
Old Jul 9, 2023 | 7:27 PM
before you panic, modules can't communicate if they don't have enough power.
Did you leave anything plugged in or turned on?
1st step: get the charging system load tested. battery+alternator
Old Jul 9, 2023 | 7:29 PM
If the codes go stored; everything will work normally until the fault occurs again. diagnose any pending or active codes. for u codes you need to know what modules set the codes and what modules have lost communication with the bus. This isn't easy and is best left to someone trained in bus diagnostics.
Old Jul 9, 2023 | 7:36 PM
what mmj said is correct. bad system voltage can cause the bus to go down. Usually, low voltage dtc will set. if the battery was dead...do what mmj suggested.
Old Jul 9, 2023 | 8:52 PM
bpolak's Avatar
I am going to do that tomorrow morning before I go to work
Old Jul 9, 2023 | 8:58 PM
bpolak's Avatar
I think its worth noting that when I was sitting in the truck the dash was doing what it wanted. The car was attempted to start without me pushing the start ignition switch. It weas going haywire kept telling me to put it in neutral and would not recognize the directons (North South East West). It kept telling me to put it in park even when i was in park. It did not want to turn on until it got to the shop roughly 45-hour after the situation had started
Old Jul 10, 2023 | 3:40 PM
bpolak's Avatar
Updating again, brought it to the shop, they did not have until the 20th. Driving it to a shop about a half hour from me who will be able to look and diagnose situation same day. Possible wiring issue (bad ground) Will follow up again tomorrow with an update.
Old Sep 30, 2025 | 4:14 PM
DadCad's Avatar
What ended up being the issue, My tahoe has had a power issue for 2 years, changed battery and it seems to only happen when the car gets wet or i disconnect trailer. along with dozens of codes (Lost communication with TCM,BCM,ECM,CAN BUS) and even dash gauges tripping out and dropping to zero while car is driving.
willil2000
Mar 1, 2025 12:44 PM
Amk1996
Apr 30, 2021 7:32 AM
glennie
Jul 29, 2020 10:11 AM
Sean Crotty
Aug 9, 2017 9:19 PM
Rachel Wolf
Mar 3, 2017 4:30 PM
