2020 3500 engine temp
Old Feb 21, 2021 | 4:00 PM
Renegade1314's Avatar
Default 2020 3500 engine temp
Good evening! My new 3500 gas engine pickup has a engine temp problem...maybe...the temp varies as i am driving, from 210-180....in that range. This is while pulling a 4 place snowmobile trailer at interstate speeds.75+
Also, the ambient temp was sub zero. Is this normal?It has 5500 miles on it . My 2018 1500 runs a steady 210. thanks for any replies or advice...
Old Feb 21, 2021 | 5:12 PM
kevinkpk's Avatar
My guess with the temperature flucuations in the low ambient tep, et. etc. is normal.
Old Feb 21, 2021 | 5:14 PM
kevinkpk's Avatar
Originally Posted by kevinkpk
My guess with the temperature flucuations in the low ambient tep, et. etc. is normal. You are seeing the thermostat operate as it should.
Old Jul 9, 2021 | 9:00 AM
Edwardmoonlight's Avatar
After the conversion of a car to gas, many car owners do not even suspect that there are moments with the Gas cylinder equipment of the car that must be taken into account during operation. I had the same problem, but after a long time, my friend and I solved this problem. In honor of this event, I decided to buy myself new tracks for my snowmobile. If you are interested click here.
Old Jul 9, 2021 | 9:04 AM
hanky's Avatar
You may not be aware that newer engines are using electrically operated thermostats.
Old Jul 9, 2021 | 11:10 PM
thermostat probably designed to start opening at 180. 210 is not a high temp imo. Don't see anything wrong here. Comparing different vehicles during different operating conditions is apples to oranges.
mediaguy
Uplander
May 20, 2017 9:27 AM
Frederic Gagne
May 15, 2017 12:27 PM
Hussain Afreed
May 21, 2016 11:04 PM
usmarine0905
Jun 8, 2011 7:53 PM
shanael1
Aug 30, 2008 5:14 PM
