3.8 Camaro backfiring and chugging
I have a 98 Camaro 3.8l v6 with a 100,000 on it. Recently the fuel pump went out, so I went to autozone and got a new fuel pump and replaced the old one once the new pump was in the car would not run right it was chugging really bad so I took the pump out thinking it was bad and exchanged it with another pump and it did not fix the problem. So I replaced all the plugs and wires fuel filter and the car was still not running right. The check engine light keeps pulling the same code cylinder 5 misfire... So I pulled all the injectors out and took a syringe and a hose and a battery and cleaned all the injectors out replaced the o rings and re installed them all with no luck the car is still running like crap backfiring under heavy excelaration it's still pulling cylinder 5 missfire codes what else could it be I don't think it could be a coil because they are double coils any help would be greatly apreciated
Cheesehead
April 9th, 2007 9:04 PM
DewAddict
January 14th, 2007 7:25 PM
kidm28
October 18th, 2006 12:28 AM
