4.3l v6 sounds like it's sucking air
Old Jan 21, 2007 | 5:05 AM
chevymandan's Avatar
Default 4.3l v6 sounds like it's sucking air
recently traded and got a GMC Saffari minivan..........i haven't really got to look into the problem too
much yet , just trying to get an idea . Starts and idles fine. when you rev up the engine it sounds like
a whirlwind of air sucking . My question is since there is minimal room under hood and doghouse
if someone could give me a general idea what it could be ????? Thankz in advance chevymandan
Old Jan 21, 2007 | 7:06 PM
CrashNburn's Avatar
Default RE: 4.3l v6 sounds like it's sucking air
has the filter been replaced with a high flow filter with an open element? made a highflow for my last blazer and you could see the hood getting sucked down when i floored it.
Old Jan 22, 2007 | 11:40 AM
jrocha3's Avatar
My guess with the information you gave, is that you have a vaccum leak. Check all the connections to and from the air filter back to the engine. Tighten them all, that should fix the problem if its a vaccume leak.
truck0220
May 19, 2013 12:55 AM
fetchmesumbacon
Jan 23, 2013 7:33 PM
erawles
Jan 11, 2011 10:56 PM
johnnyz
Aug 23, 2009 2:31 PM
stumpman
Jul 12, 2009 9:32 PM
