4x4 doesn't work-HELP!
Old Dec 17, 2007 | 4:53 PM
sixpack_sid's Avatar
Default 4x4 doesn't work-HELP!
Ijust boughta '94 S15 GMC Jimmy AT w/push button 4x4. When I tried the 4x4 switch it blinked 3 times but didn't engage. Now it doesn't do anything when I push the button. Any ideas on what could be the problem? I live in the Northeast & NEED 4x4! Any help would be appreciated!
Thanks!
Old Dec 18, 2007 | 8:02 AM
John86's Avatar
Default RE: 4x4 doesn't work-HELP!
like the button doesn't blink or wat? either ur switch or an encoder motor.
Old Dec 21, 2007 | 10:50 PM
techboy07's Avatar
ok, there are two very comon problems that i see every week with electronic4X4. first is the switch. but since it is blinking like you said it is, i am going to guess that you are in need of an encoder motor. you can pay more than you want to from the dealer, or you can pull one from a wrecking yard truck. keep us posted.
Old Dec 23, 2007 | 11:06 AM
RCars2's Avatar
Here is something that may help ya out to get the 4x4 to work (works on my 2000 so its worth a try). When trying to get the 4x4 to engauge try driving forward a few feet and then reverse a few feet and keep cycling back and forth while trying the 4x4. It might take a few tries but it should get the t-case to shift into 4x4. If that dont work shift into neutral and try 4 low. For some reason the t-case usually has an easier time doing that than 4hi. If you can get it into low it usually will allow you to get into 4hi from there.
ZiL
Uplander
Feb 15, 2011 8:45 PM
mattdez
Jun 5, 2010 10:44 AM
04Cav
Apr 20, 2008 8:01 PM
EdM
May 23, 2007 2:14 AM
burnsze15
Jan 3, 2007 2:57 PM
