700R4 won't go into any gear
Old Nov 7, 2012 | 8:47 PM
cimchazz1's Avatar
Default 700R4 won't go into any gear
Hope I'm in the right forum for this, the trans is in a 1991 Corvette, but I don't think it's an issue that's only a Corvette issue, so here goes:
When I bot this car, it only moved in 2nd gear (when in drive) and reverse (but downshifted to 1st sometimes). I changed the fluid and filter, and nothing changed. I got it to shift a few times playing with the TV, but it wasn't consistent or long lasting, but shifted through all gears well. So I raised the front of the car about 9", got under it, and pulled the governor and found a "dished" out spot on one side of the gear, like the governor had stopped moving and got stripped out by the output shaft. So I put a new gear in and put it back together. I lost probably 1-2 quarts of fluid out the governor hole, I'm guessing. I lowered the car back down and started it (in park) to check the fluid and fill it. After about 30 seconds, I heard some loud "clicking sounds, and the engine started to "labor", so I shut it off quick. I checked the trans dip stick and the fluid was about 3" high on the stick. I started the engine again and the fluid level didn't change and the car wouldn't go into any gear, but the engine slowed down about 100rpm when I put it in gear and there was a steady clicking sound from the front of the trans, like a hyd lifter click. I am guessing it is stock original, but who knows. The car has 130,000 miles on it. The fluid I took out wasn't burned, and was light pink, with no chunks of anything. One shop I spoke with told me if the trans oil is low it won't go into gear, but that shouldn't do what I am describing just sitting in park. I checked my FSM, and didn't get much out of it.
I haven't dropped the pan again yet, but am wondering if anyone who knows anything about these transmissions has any idea what might have happened to this one? Thanks
scoobdj01
11
Jul 20, 2018 10:54 AM
r3333d
Jul 24, 2014 9:16 AM
Like_A_Rock
18
Feb 10, 2011 12:06 PM
ed1le
Aug 18, 2008 9:12 PM
jjohnson
Feb 15, 2007 6:44 PM
