91 k1500 5.0 issues help me
OMG HELP ME!!! LOL
Symptoms: check engine light comes on, headlights dim drastically, truck seems to flood out. All of these things happen simultaneously. If the lights are bright the check engine light is off and the truck runs fine. It does this idling in park, reverse, drive, bumpy roads, smooth road etc.
Things I’ve checked\replaced: Has brand new Oxygen sensor and fuel filter. I have put 2 large bottles of fuel injector cleaner in the tank. The truck had just got a brand new starter installed before I bought it. The truck also runs this way with or without the breather box assembly. I haven’t yet got to the fuel tank to clean it. I still can’t figure out if it is an electrical problem or a fuel problem or a mixture of both. Also the truck has been run with 3 different batteries so that eliminates the battery. I took in the alternator to get checked. The test showed slightly below where it should be, but it held steady at that voltage and didn’t fluctuate.
I dropped the tank and it had about a 1/2 inch of water and crap in it. i got every drop of that stuff out and the truck ran better but still has the issues it had before. i unplug almost every wire plug under the hood that i saw and sprayed them down. i also did this with the spark plug wires. i popped off the distributor cap and sprayed the rotor button also. none of this solved the problem. i then took a small piece of wire and stuck it in the upper right two plug holes of the OBD plug under the dash. the service light flashed 12 over and over, which tells me that the OBD detects nothing. ANY IDEAS?
Is the truck running rough before the the lights dim?
If the lights dim before the truck starts runnig rough... it's an electrical supply problem.
If the voltage is too low the CPU and the injectors will be confused.
My bet is either your alternator or your cables.
Free_Bird12
Dec 19, 2017 7:28 AM
Free_Bird12
Jun 4, 2014 9:29 PM
Samantha Rose Newman
Oct 16, 2013 2:57 AM
