96 K1500 fuel pump issues?!
Old Jul 10, 2013 | 11:48 PM
mistyrachelle's Avatar
Unhappy 96 K1500 fuel pump issues?!
I have a 1996 K1500 Chevrolet truck 4WD 5.7L, I had the fuel pump replaced last month as well as the relay. Before I replaced the pump, it wasn't getting fuel pressure. It would just crank, and not start. So I changed the pump and it started about 5 times, then about the 6th time it just kept cranking over not starting, so I was back to the same problem as before. I then replaced the relay and it worked. It's been sitting for a few weeks, went to drive it and it cuts out really bad to the point it dies while driving. Now it's not wanting to start and when it does, it will only stay running for a second then die. Please help! I also wanted to note, that there is a hot wire running from the pump into the relay!? The relay itself is also getting hot to the touch.. If anyone could help me figure out what to do next, besides run this thing off a cliff - it would be greatly appreciated! Thanks!
Old Jul 28, 2013 | 9:41 PM
go-part's Avatar
Former Sponsor
Check the wiring that goes to the fuel pump.
http://community.cartalk.com/discuss...ay-getting-hot
Old Aug 11, 2014 | 3:57 PM
Pettywe1's Avatar
I have a 98 Chevy Cheyenne 6cyl. truck. I am having problems starting it. But once I get it started it starts all day perfectly. I have changed the fuel Filter out and I am still having this problem. Help!!
Old Aug 17, 2014 | 8:15 PM
Rftlts's Avatar
If I remember correctly the fuel pump power is staged. With the key in start, there is power to the pump. But after releasing the key back to run position the power to the pump goes through the oil pressure switch. You will need to check all the wiring. A temperature "hot" wire or relay is cause by a over current condition. Which can be caused a lot of different ways. Always check what was last done for any issues. Pinched wires etc. bad ground connections. Check to see if the pump is supposed to cycle on and off.
mangomanj
Aug 17, 2014 9:51 PM
mistyrachelle
Jul 10, 2013 11:40 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
scottkern3
Dec 7, 2009 7:53 PM
