'97 Burb - Power Steering Pump - How to install Inlet Valve on pump body - Replacing
Guys
Thought already posted this inquiry, but not finding it - apologies if duplicated my request.
1997 Suburban K-1500 w/5.7 Vortec
I need help - How to install Inlet Valve on pump body - Replacing Power Steering Pump
Having trouble installing High Pressure inlet valve into replacement PS pump.
Swapping parts off of old pump to put onto new pump and can only start threading Inlet Valve then just stops and will not continue too go all the way in and seat.
Pulled the old one off and it popped right out, but after replacing w/new O-Rings won't go in...?
Tried putting it back into old pump and same problem... will only go in a bit and then stops - did not want to force it and break something.
Is there some kind of a installation trick to get the Hi pressure inlet valve body back into the PS pump?
Appreciate any advice on this.
Did not expect a problem, now car is down and no other wheels right now.
Best regards,
Lfryklu
Best regards,
Lfryklu
Lfryklu
December 22nd, 2019 3:32 PM
buddho
February 5th, 2015 9:52 PM
BlackDog
November 15th, 2011 4:22 AM
