'97 Burb - Power Steering Pump - How to install Inlet Valve on pump body - Replacing
Old Dec 22, 2019 | 5:26 PM
Lfryklu's Avatar
Default '97 Burb - Power Steering Pump - How to install Inlet Valve on pump body - Replacing
Guys
Thought already posted this inquiry, but not finding it - apologies if duplicated my request.
1997 Suburban K-1500 w/5.7 Vortec
I need help - How to install Inlet Valve on pump body - Replacing Power Steering Pump
Having trouble installing High Pressure inlet valve into replacement PS pump.
Swapping parts off of old pump to put onto new pump and can only start threading Inlet Valve then just stops and will not continue too go all the way in and seat.
Pulled the old one off and it popped right out, but after replacing w/new O-Rings won't go in...?
Tried putting it back into old pump and same problem... will only go in a bit and then stops - did not want to force it and break something.
Is there some kind of a installation trick to get the Hi pressure inlet valve body back into the PS pump?
Appreciate any advice on this.
Did not expect a problem, now car is down and no other wheels right now.
Best regards,
Lfryklu
Old Dec 22, 2019 | 6:11 PM
kevinkpk's Avatar
I'd suggest look at the threads on both valves, they look the same pitch, or not? If both are the same, get a wrench on it.
Old Dec 22, 2019 | 6:13 PM
kevinkpk's Avatar
Could be the O ring is just hanging up, use a little bit of PS fluid on it.
Old Dec 22, 2019 | 6:52 PM
Lfryklu's Avatar
Figured it out... Brain fart....
Sorry to have bothered you,.
Best regards,
Lfryklu
Old Dec 22, 2019 | 7:58 PM
Rednucleus's Avatar
What was the problem - my brain does that at regular intervals!
Barmaley
Nov 27, 2019 12:53 AM
buddho
Feb 5, 2015 9:52 PM
BlackDog
Nov 15, 2011 4:22 AM
VANZILA
Jan 26, 2008 10:19 PM
