99 suburban heat issue
Old Mar 6, 2012 | 7:26 AM
tommyxj2000's Avatar
Default 99 suburban heat issue
when im driving heat is blowing out nice and hot...when im stopped it turns cold...topped off antifreeze,.... had changed intake gasket due to leak and little sensor on firewall...doesnt over heat at all
Old Mar 6, 2012 | 6:52 PM
EinST's Avatar
Is it RPM-dependent? Higher RPM would mean higher water pump output pressure to overcome any restrictions in the heater core.
Old Mar 7, 2012 | 9:24 PM
cleveland63b's Avatar
agreed could be a clog or failing waterpump
Old Mar 7, 2012 | 9:34 PM
MDTAHOE's Avatar
Professional Mechanic
I agree with restriction in heater core. Most likely not a water pump problem.
Old Mar 11, 2012 | 7:52 PM
evans906's Avatar
Default Re: 99 suburban heat issue
I agree with EinST, If the heater core was pluged there would be now heat at all. To check the heater core check both hoses going to the heater core at the firewall, they both should hot, if one is hot and the other is cold then you have a plugged heater core.
Old Mar 11, 2012 | 9:31 PM
MDTAHOE's Avatar
Can none of you understand EinST post. He did not say anything was wrong with the water pump. He said that if the heater core had any restriction in it when the rpm raises the water pump moves faster creating more pressure. That extra pressure now can move through the restricted heater core.
Water pumps do not fail in any way that will cause a heat problem. In very rare instances a water pump impeller can fail in such a way that they do not move enough coolant at idle,thus causing a over heating condition.
Old Mar 11, 2012 | 9:33 PM
MDTAHOE's Avatar
No body said anything about a plugged heater core. A restricted core will still flow coolant just not enough.
Old Mar 12, 2012 | 10:19 PM
I've had a fair amount of plastic impellers have a couple fins break, hot at cruise barely warm at idle. Going off of theory it didnt make much sense but parts don't lie.
Chevmann92
Jan 3, 2014 2:03 AM
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
