99 Tahoe Stuck in 4wd Low
Old Dec 6, 2019 | 2:45 PM
Gregory B's Avatar
Default 99 Tahoe Stuck in 4wd Low
Hello All, I am a new poster here and hope someone can assist with this diagnosis.
I have a 2 door 1999 Tahoe z71 sport 4x4 that is stuck in 4wd. I had replaced the actuator at the differential a few years back so I wanted to know how to diagnose if it is that again or the TCCM..
Here is what its doing. It is in 4LO, and when I put it in neutral and try to switch to 4HI, 2HI or Auto the light blinks, but the light for 4LO stays lit up. There is a clicking under the dash when I try push buttons to shift.
I have unhooked battery for 30 minutes, removed the ecm1 fuse for 40 seconds, cycled ignition switch 5 times to clear..... but it still does the same thing...it is stuck in 4LO. I removed the Actuator and its piston can be pressed in and pops back out. Before I spend the money on a new TCCM or another Actuator, I thought I better see if anyone knows how I can diagnose this.
Also, is there a manual way to push in the differential plunger (where the actuator sits) to MANUALLY put this in 2 wheel drive?
Any help will be appreciated.
Old Dec 6, 2019 | 2:55 PM
kevinkpk's Avatar
Can you just shift the transfer case with actuator removed. If the actuator is mechanically rolling the transfer case back, leave it out till you can get a new actuator.
Old Dec 6, 2019 | 3:05 PM
Gregory B's Avatar
That is what I am wondering. How far or how many times do I press it in to make it go into 2wd?
Old Dec 11, 2019 | 11:37 AM
Gregory B's Avatar
Since it doesnt seem that this forum is active or has info, does anyone know another forum that may have the info I need?
Old Dec 11, 2019 | 4:44 PM
kevinkpk's Avatar
I might be wrong, but isn't the shifter on the transfer case where you could just use a wrench to move it between modes?
Old Dec 11, 2019 | 5:00 PM
Gregory B's Avatar
It is a plunger type apparatus. And I am hoping that the thing can be pushed in manually but dont have a helper right now so was hoping someone here knew the procedure. I am getting the impression this isnt a high traffic forum.
Old Dec 11, 2019 | 5:34 PM
kevinkpk's Avatar
Have you tried youtube? I am not familiar with your transfer case. I had a 2000, this was an actuator that attached to the shifter shaft external to the transfer case, use a crescent wrench to shift it manually without the actuator.
ADSMITH
14
Mar 13, 2013 8:21 PM
bob2010
Feb 1, 2010 6:42 PM
K1500notSilverado
Nov 17, 2009 2:40 AM
GAT57
Aug 2, 2009 7:04 PM
Dennis B
Feb 24, 2009 10:05 PM
