ABS reluctor on rear pinion for 3.90 gearset
Old Feb 17, 2009 | 6:30 PM
danlsmith's Avatar
Default ABS reluctor on rear pinion for 3.90 gearset
Dealer tells me that these parts are discontinued and can not be ordered. I want to swap the rear gears in my '96 Roadmaster from stock 2.45 ratio to something like a 3.70 or maybe a 3.90, using a brand that will accept the stock anti-lock brake reluctor (the thing that slips over the pinion shaft, has metal teeth on one end). I will need the right matching reluctor for the anti-lock brake circuit. Anyone have any idea where I can get the one that will work with a 3.70 or 3.90 ration ring and pinion? FYI... this is a Roadmaster so it has the 'corporate rearend'.
Old Feb 20, 2009 | 1:21 PM
danlsmith's Avatar
Default Found!!!
Found my own answer... here it is to help if you or anyone else may need it. GM part no.s are
26018944 for 3.23 ratio & reluctor has 22 teeth
26018945 for 3.42 ratio & reluctor has 20 teeth
26018946 for 3.70 ratio & reluctor has 18 teeth
26018947 for 4.10 ratio & reluctor has 16 teeth
Order from www.drivetrainspecialists.com
pick the reluctor closest to the ratio gears you are changing to
cjfelsinger
May 27, 2014 3:46 PM
BIGREDDNESS
Feb 20, 2012 10:07 PM
Ole' Blue95
Dec 27, 2009 1:52 AM
Zeke
Sep 27, 2006 2:32 PM
