Ac not working
Old Jun 10, 2015 | 5:33 AM
Greybomber90's Avatar
Default Ac not working
My alternator went out and I replaced it but now my ac doesn't work at all, all components are brand new due to having it repaired 2 months before charge is good no leaks can't find the problem please help!!
Old Jun 10, 2015 | 5:37 AM
Was the A/C working before the alternator change? If it was then check all the wiring around the alternator for problems and don't forget to check the A/C fuses and relays.
Old Jun 10, 2015 | 6:39 AM
Yes the ac was working just fine I'll check the specific fuse and as far as the relay I know there's three behind my glove box which one would I need to remove and replace ?
Old Jun 10, 2015 | 2:49 PM
Check to see if they are all exactly the same. If they are then you can swap them around to see if the A/C starts to work and something else stops working. Check the fuses first.
Old Jun 10, 2015 | 6:29 PM
fparkin's Avatar
is alt correct size? is battery full charge ac clutch take lot current
Old Jun 15, 2015 | 2:02 AM
josepmccoin's Avatar
Have you verified if they are the same?
Merkel3594
Jan 7, 2022 10:33 PM
Scoobysam
Mar 29, 2015 9:30 AM
ezzyboy954
Feb 9, 2011 12:12 PM
mcarlson14
Jul 11, 2006 1:33 PM
Omnious
Jun 11, 2006 11:43 AM
