Bar's Leak for coolant leak
Old May 24, 2008 | 11:11 PM
95wt's Avatar
Default Bar's Leak for coolant leak
I have a small coolant leak maybe coming from the rear of the intake manifold. I thought about using Bar's Leak on it. Without slamming me for considering this please (I know fixing it the right way is better), what are the pros and cons of Bar's Leak on it? [/align][/align]
Old May 25, 2008 | 6:47 AM
shawnvw's Avatar
Banned
Default RE: Bar's Leak for coolant leak
Pro - cheap
Con - only temporary
- run the risk of plugging the heater core
Old May 25, 2008 | 2:22 PM
95wt's Avatar
How big is the risk of damage to the heater core? Are there any factors that tend to make it more likely or less likely?
Old May 27, 2008 | 6:40 AM
shawnvw's Avatar
Banned
I've seen it happen about 1 out of every 10 times people use it. If it does happen you just need to flush the heater core.
Old May 30, 2008 | 3:07 PM
95wt's Avatar
Thanks Shawn.
I ended up deciding against using the Bar's Leak, so I can't help anyone who might be searching for results on using it. I took the truck to the shop to see how much it would cost to fix and it turned out to be the freeze plug above the starter and only cost $77.00 parts and labor to have fixed. It was an easy choice. [/align]
dlaroche
Oct 29, 2014 7:17 PM
formulalt1power
Mar 14, 2007 6:34 PM
ffdaryl
Mar 1, 2007 2:52 AM
bc56845
Nov 29, 2006 2:12 AM
