Bcm and ecm question
Old Mar 6, 2020 | 9:22 AM
not2bad's Avatar
Default Bcm and ecm question
If you have a faulty bcm and pull one from a yard matching your vehicle, you need to have it flashed by a dealer to get it to work. Instead of that why couldn't you pull both the matching ecm and bcm out of the same vehicle instead? Why would wouldn't it work and save yourself the money and grief of reflashing? Granted you would have to do a relearn,ok, but if you bypassed the key(resistor, etc.) why shouldn't it work? Thanks.
Old Mar 6, 2020 | 7:55 PM
depends on the vehicle build..some have a separate theft module outside of the bcm and ecm.
if you have a transponder key you couldn't relearn the key to the new pcm would have to cut and program a new key.
Old Mar 6, 2020 | 8:09 PM
I think you would need to replace EVERY module, and modern vehicles have quite a few.
rnorman4
Sep 10, 2022 9:31 AM
husein-p
Dec 13, 2019 6:18 AM
dZire
Apr 29, 2017 11:45 PM
alxsml
Apr 9, 2013 11:21 AM
jackalrs
Dec 8, 2012 10:25 PM
