question about ecm v6 vs v8 ecm
Old Dec 9, 2019 | 2:30 PM
husein-p's Avatar
Default question about ecm v6 vs v8 ecm
Hey guys
I have a important question about ecu-ecm
My engine is v6 4.3L 1992
I bought this engine without ecm now i wanna buy an ecu for this engine but i dont know i can use 8 cylinder 305 or 350 ecm on this engine or not i must buy 6 cylinder ecm only ?
Somebody can hlp me plz
Tnx
Old Dec 9, 2019 | 2:54 PM
Yes the ECM has to match the engine so it doesn’t try to fire non-existing cylinders! Unless you can find someone to reprogram it.
Old Dec 12, 2019 | 2:07 PM
husein-p's Avatar
But that is tbi system not mpi system and has a distributer system
You know ? You crrect ?
I think ecu just wanna run the engine with 2 injector on throthle body and ecu not important im wrong or not ?
Old Dec 12, 2019 | 2:34 PM
Maybe but the ecm expects the correct impulses on crankshaft sensor. Maybe 1992 doesn’t I don’t know. Try it and see.
Old Dec 13, 2019 | 6:18 AM
husein-p's Avatar
These models hasnt crankshaft sensor and ecu work with spining the distributer shaft ....
Then with map info and tps info calculate fuel injecting
But i dont know this model has a oxygen sensor or not if has oxygen sensor with this sensor can optimize fuel usage ...
But i wanna use new seimense no immo ecu with trigear on crankshaft pulley and crankshaft sensor with this way i have his diag because is obd ii but chevrolet old ecu is obd 1 !
Barrett@autodamageexperts.com
Jun 20, 2018 8:17 AM
alxsml
Apr 9, 2013 11:21 AM
jackalrs
Dec 8, 2012 10:25 PM
astrofast4.3
Oct 31, 2010 2:24 PM
TravisJ
Oct 9, 2007 10:35 PM
