brake light issue
Old Sep 23, 2011 | 4:29 PM
brystacer's Avatar
Default brake light issue
Hi, im new to the site. I have a 1991 s10. runs great except now i dont have brake lights or turn signal lights. i have headlights and parking lights but thats it. i checked the bulbs and fuses but have no clue where to go from here. pretty new at this. any advice on where to start would be very appreciative. thanks!!
Old Sep 23, 2011 | 4:42 PM
patriot0331's Avatar
did you try replacing your juntion box? had to replace mine when the blinkers were blinking faster than normal.
2003 Avalanche 1500
4X4
V8 Vortec
Old Oct 1, 2011 | 6:44 AM
Realta1k's Avatar
Sounds like you have and open somewhere. To sniff this out you need to get yourself a or digital volt/ohm meter. Start at the fuse box and work you way back making sure you have 12 volts: 1st @ the fuse then 2nd on the wire at the light. If 12 volts are there next you would check for ground continuity. The black wire going to the light housing is typically the ground wire. Make sure this wire has a good zero ohm connection with the chassis. If not zero, splice into this wire and make a new ground connection. This should fix your problem.
Old Oct 25, 2011 | 10:59 AM
tractorman1154's Avatar
It might be your circuit board back there, mine went out in my 2000 chevy k2500 and it was only $30 to replace them.
TruckManDan
Dec 25, 2014 7:52 AM
Slobby Baymon
Nov 12, 2013 11:52 PM
WTH275
Dec 12, 2011 5:26 PM
beckya99
Jul 12, 2011 12:29 PM
clintjohns6412
Sep 14, 2007 7:19 AM
