Brakes and Rotars Really
Old Apr 16, 2013 | 7:51 PM
fschlenter911's Avatar
Default Brakes and Rotars Really
Hello,
I have a large Chevy vehicle with 80K. Just had it checked out and I am being told that its best to replace both pads and rotars. Pads are getting there but there is no indication of bad rotars. Is this what I should do. Wy not put new pads on and keep on driving?
Thanks and really appreciate your thoughts?
Old Apr 16, 2013 | 10:50 PM
go-part's Avatar
Former Sponsor
Should I resurface or replace my rotors everytime I replace brake pads? - Motor Vehicle Maintenance & Repair Stack Exchange
If you tell me the model and year of your vehicle I can tell you how thick the rotors should be before you should replace them.
Old Apr 17, 2013 | 11:18 AM
Official GM Rep
Originally Posted by fschlenter911
Hello,
Fschlenter911,
I would like to look into your situation. Are you working with a certified GM dealership?
Erica Tiffany
Chevrolet Customer Service
Old Apr 17, 2013 | 2:05 PM
kevinkpk's Avatar
I don't. The reason is to true up the surface for new pads. After a couple brake jobs, the rotors can be undersized, and hve to be replaced.
Old Apr 17, 2013 | 2:12 PM
Depending on the vehicle, the rotors are relativity inexpensive... a set of front pads AND rotors for an 07 Tahoe go for about $140
I'd replace them...
Old Apr 18, 2013 | 12:49 PM
SWHouston's Avatar
fschlenter911,
It's nice to have brand new Rotors and Pads on your ride, can't get any better than that.
Likewise, when you turn your Rotors to perfectly flat, that's just about as good, but there's a limit on how many times that can be done, as stated.
But there is a reasonable amount of wear a Rotor can have, and still function well enough, by just replacing the Pads. The idea of this type replacement is NOT to let any metal of the Pad, touch the Rotor, which will really mess it up. Doing just the Pads will allow them to settle into the irregularities of the Rotor, and extend the period of a major expense.
Someone with experience, and a Micrometer, can make a judgment on that for you. The problem with that is, you need to find someone who will look, measure, and give you an honest opinion on what to do.
JRich_taco
Aug 31, 2013 12:16 AM
yukon2001
Oct 30, 2012 8:53 PM
Mille Racer 69
Dec 8, 2010 8:26 PM
Fmlywgn
Sep 20, 2007 9:11 AM
