broken flywheel
Old Dec 17, 2007 | 8:54 AM
snowplow's Avatar
Default broken flywheel
I have a 01 2500hd 6.0 automatic 4x4. The flywheel keeps breaking. Had trans rebuilt lastyear. Aftermarket flywheel broke in 2 months. Replaced with Chevy flywheel and new converter. This lasted 10 months. Noone at trans shop or dealerhas any ideas. Thanks.
Old Dec 17, 2007 | 9:56 AM
cplthomas's Avatar
Default RE: broken flywheel
define breaking. teeth sheering? crack in wheel?
Was the aftermarket one lightened? Some hi-perf applications will lighten the flywheel for weight. And some will use stock or HD for fuel economy (keep rotational inertia going). Perhapd you simply need a heavy duty one.
Old Dec 17, 2007 | 2:29 PM
John86's Avatar
sounds like something is not aligning right and putting it into a bind. or the flywheel bolts maybe over tightened.
Old Dec 18, 2007 | 7:17 AM
snowplow's Avatar
Flywheel isbreaking around where it is bolted to engine. Flywheel is stock for a HD. Bolts are to specified torque.
Old Dec 18, 2007 | 8:05 AM
astroDZak's Avatar
Its uncommon but on occasion the thrust washer on the crankshaft will be worn and allow the crank to move back and forth. Its kind of like taking a wire and bending it back and forth eventually it will break.
Old Dec 18, 2007 | 8:06 AM
John86's Avatar
sounds like something is binding up then. maybe bad trans mount or motor mount. the bell housing may not have been aligned right when bolting back up to the trans after ur rebuild. do u have ne trans fluid leaking from the from pump area??
Old May 2, 2020 | 6:46 PM
Steve Shaffer's Avatar
1988 chevy 1500 small block 350 outer part of flywheel broke from center cant get bolts out what can i do to get them out
hajboj
May 15, 2008 10:05 PM
sbudac
Mar 20, 2007 4:38 PM
WGVette
Sep 27, 2006 2:48 PM
Zeke
Sep 27, 2006 2:32 PM
mrl
Aug 31, 2006 12:23 PM
