A/C Problem
Old Jun 14, 2023 | 11:50 PM
Reefkeepa's Avatar
Default A/C Problem
I have a blend door question. After looking at a bunch of exploded diagrams online I was wondering if someone could point me in the right direction. This past winter my defrost blend motor stopped working and luckily it was the one that’s easy to change by the center duct. Now I’m having what I think is the other door not closing off the heat side when the A/C is on with the recirculating vent open. When you hit the button to make it recirculate it gets cold. Is there a door somewhere that I’m missing because the one shown on the bottom passenger side in the diagram isn’t on my truck. I can see where it would be but its not cut. I’m just asking here to see if anyone knows if this is a common problem. I forgot where I saw the diagrams but I probably just googled it. I really don’t want to take all that airbag crap out for no reason.
Thanks.
2007 GMC Sierra Regular cab WT
Last edited by Reefkeepa; Jun 14, 2023 at 11:52 PM. Reason: Forgot make model information
Old Jun 15, 2023 | 1:55 AM
oilcanhenry's Avatar
Thanks.
On my 1998 K-1500 Chevy 4x4 there are supposedly three actuators. The one I had to change out was the easy one above the gas pedal. Easy to get off with 5.5mm socket but a bear to get the one closest to the firewall, back in. Using a magnetized socket I finally got it back in without stripping the plastic climate control box. The other two look really hard to get to, but certainly possible. I'll have to try to find a schematic on the 2007 actuator locations to Dx this issue. I never use the the recirculating vent, but it still works.
Old Jun 16, 2023 | 6:23 AM
Thanks.
I found this Youtube video that might help you to replace your climate control actuator. The actuator on my 98 K-1500 is nowhere near this location, but of course, nothing ever stays the same:
Old Jun 16, 2023 | 8:07 AM
Reefkeepa's Avatar
https://www.youtube.com/watch?v=Eqf-H3COtSo
Thanks. That’s the one I changed this winter. However I see in a related thread someone with a very similar issue. Good forum.
Old Jun 16, 2023 | 8:20 AM
Reefkeepa's Avatar
OK. It’s on the top inside the dash. I wonder of GM will give me a new air bag since it’s in a recall. I guess I’ll get the recall done at the dealership which I dread. Then take it out and change the actuator. PITA. Or. or I might just leave the airbag light on till it burns out.🤷🏻‍♂️🤣🤣🤣🤣
Barry A. Waters
Aug 17, 2019 11:12 AM
sgniogs
Apr 21, 2017 10:28 AM
Todd Bridge
Oct 14, 2013 12:54 PM
SuperTexan
May 1, 2012 7:55 PM
