C2500
Old Mar 15, 2019 | 2:43 PM
Crazeerebel's Avatar
Default C2500
Hello all I have a 98 c2500 with 5.7 vortec that has me scratching my head.I’ve replaced the following:injectors,plugs,wires,distributor cap,egr valve, fuel pump,ignition control module,fuel filter. I’m still having a skip in it and if you give it throttle while taking off it almost cuts off. It’s not throwing any codes that’s why I can’t figure out what’s wrong any help or advice would be appreciated!!
Old Mar 16, 2019 | 2:15 PM
oilcanhenry's Avatar
Did you clean the MAF sensor yet? Sometimes they need cleaning/replacement but wont throw a code.
Old Mar 17, 2019 | 11:14 AM
Default c2500
Thought that might be the problem seen couple videos said to unplug MAF sensor with engine running if continued to run that was the issue I unplugged mine and it continued to run so gonna try cleaning or replacing it will update
Old Mar 17, 2019 | 12:44 PM
Let us know if it worked.
