Old Jul 24, 2015, 4:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
camshaft position sensor
Old Jul 10, 2007 | 1:23 PM
boydbl's Avatar
Default camshaft position sensor
I have a 2001 chevy tracker automatic with the 2.0 engine. I had thecar checked out at a local shop and was told that the camshaft position sensor was bad. I called around and found one at autozone for 76.00. I purcashed it and brought it home to put it on. I took the old one off and installed the new one, now the car wont start at all. I then took the new one off and reinstalled the old one and the car started.The car wont run but approx. 30 minutes before it starts to sputter and stall and then will not start back up until I let it sit for a while. Is there a special way to install a new camshaft sensor or is there something else wrong with the car. Does it anything to do with the timing and if so how do I install the new one. The code that I am getting from the service center is P0304 Camshaft position sensor.
Thanks Brian
Old Jul 10, 2007 | 4:07 PM
golfer's Avatar
Default RE: camshaft position sensor
Scroll down the forum for the Tracker section. There is a thread describing the problem with the sensor.
Old Jul 10, 2007 | 4:59 PM
boydbl's Avatar
Found it thanks
Pearlwhitez28
May 21, 2016 3:24 AM
Phill S.
Jan 1, 2013 3:10 AM
kfortman
Jul 20, 2010 10:59 PM
derry
Jun 9, 2007 4:26 PM
