Can I Remove AIR system
Old Jan 26, 2012 | 7:47 AM
heavy9's Avatar
Default Can I Remove AIR system
I have an 86 chevy c10 with the stock 305. I really only use this vehicle on the weekends to go to lowes, home depot, haul lawn mower to my dad's house, etc. Not a daily driver. Also I should metion it does not have to pass emmsions and has an "antique" tag on it.
I just recently acquired this vehicle from a realtive (first mistake..lol) and although it ran I new it had some problems. I have removed the carbureator (quadrajet) and installed a new eldelbrock. (before the bashing begins understand that I am not a vehicle mechanic and my knowledge is limited and I was told by someone I trust to put this new one on because unless I know what I am doing with the quadrajet I might have issues fine tuning it.) I may not be a true mechanic I like to use this one to learn on so I do all of the work myself (within reason). While I am at it i have put all new hoses, thermostat, etc.
Now to my question... Can I remove the AIR (air injection reaction) system? (smog pump,air injection pipe, diverter valve,check valews, etc.)
My limited knowledge says yes and all I should have to do is make sure I plug the exhaust ports where I remove the tubes so I dont have an exhaust leak under the hood. Everything that I find leads back to the emmisions and I do understand and respect that but in my current situation I dont think that would apply. Thanks for the help.
Old Jan 26, 2012 | 8:24 PM
MDTAHOE's Avatar
Professional Mechanic
Why do you want to remove it?
Old Jan 26, 2012 | 9:52 PM
heavy9's Avatar
Someone else asked me that same question at work. Basically just to clean up the engine also since I'm new to this I wanted to remove anything not needed so that I wont be confused in the future. Right now as it stands its kinda "busy" under the hood and I thought removing some of that stuff might just clean it up a bit. I think back to my 76 GMC truck (yes i know its a 76 not an 86) and it was clean.. not all of that emissions.... stuff. You could actually get in there and work. ..........So in a nut shell ........its purely aesthetics...lol
Old Jan 27, 2012 | 6:54 AM
MDTAHOE's Avatar
Yes you can remove it.
Old Jan 28, 2012 | 5:51 AM
heavy9's Avatar
Thanks
Old Aug 5, 2012 | 8:43 AM
SImpleManFore's Avatar
How Can You Remove It I Have A 90 K1500 With Smog Pump
Old Aug 5, 2012 | 1:49 PM
kevinkpk's Avatar
X2. As far as the quadrajet, I'd never have anything but. You are correct with tunning them, once you get the jets matched to ect, it is IMHO the best. I have a 2gc on my delta 88, if I ever get partially out of debt, I'll slap a quad on that 455.
Old Apr 15, 2017 | 5:26 PM
MAzing's Avatar
Default A.I.R. System
how and will it set a code
troysee
Mar 18, 2017 8:01 PM
silverado 1500 2001
Sep 14, 2014 7:41 PM
Nekramess
Jul 3, 2014 6:52 AM
surfandride
Jan 16, 2011 10:05 PM
mystikal1000
Jan 21, 2008 12:18 PM
