Car won't start, ticking in fuse box, battery is fine.... long story..
Old Mar 25, 2025 | 2:28 AM
Erichm1987's Avatar
Default Car won't start, ticking in fuse box, battery is fine.... long story..
so I decided to install a amp and sub into my car and amidst the chaos of trying to hurry (first mistake) and complete this I reverse the polarity by connecting the positive to the ground and ground to the positive on the amp. since then I was able to start my vehicle once with the check engine light coming on. the next day I went to start it and nothing. I realized that I reversed those two wires and disconnected the battery and the 2 wires although I'm sure the damage was already done. now when my battery is connected I get a ticking noise coming from the fuse box. when I inspected it I noticed the ignition sw batt2 fuse was blown and when I turned the key my RPMs would shoot up but no other gauges worked. I replaced that fuse and in doing so, the ticking noise began, which turned out to be the alc prk lmp ctrl relay. I've tried putting in a different relay, reconnecting the battery, and still the same result. only now I turn the key and I get nothing from anywhere. so my questions are... could this be a starter relay, starter, or alternator issue if no other fuses/relays are blown, or did i fry my entire electrical system? (although i thought that's what the purpose of these fuses were to prevent) and what is the best approach/steps that should be taken in this process of elimination and how should i go about this? please and thank you's to all who can help
Old Apr 13, 2025 | 10:57 AM
Welcome to the forum. You might want to post your question in the section of the form specifically for your vehicle where you might get more views.
reywas
Nov 29, 2023 1:38 AM
watersteps
Uplander
Mar 5, 2018 10:40 AM
skidooxps
Jun 7, 2014 9:22 PM
tomwalt
Dec 3, 2013 12:05 PM
olred87
May 31, 2010 11:58 AM
