Rebuilding Chev 350 SMB, once I tighten / torque the Con Rod Bolts, Engine wont turn
Old Apr 13, 2025 | 1:28 PM
Robert Se's Avatar
Default Rebuilding Chev 350 SMB, once I tighten / torque the Con Rod Bolts, Engine wont turn
Dear All,
I am Rebuilding Chev 350 SMB, I got the block professional machined. I installed new pistons and rings, as the Con Rod bolts are ruffed in loosely the engine turns manually (but is still slightly hard). However once I tighten / torque the Con Rod Bolts to Connecting Rod Bolt 38ft.-lbs/ (52 NM), the engine no longer turns. I have attached a video of the engine turning before torqueing the con rod bolts. Please advise what I am doing wrong. Thankyou in advance.
Yogi
Nov 5, 2016 6:35 PM
sleeper79blazer
K5 Blazer
Aug 5, 2010 12:06 AM
atlbigboi
Mar 27, 2008 7:43 PM
atlbigboi
Jul 27, 2006 9:07 AM
