K5 Blazer 1969-1994
Platform: Truck, GMT 400
1979 k5 blazer: Any engine removal tips??
Old Aug 3, 2010 | 12:46 AM
sleeper79blazer's Avatar
Exclamation 1979 k5 blazer: Any engine removal tips??
Just wondering if there were any "tips" I might need to remove my sbc 350 from my 79 k5 with th350/np 203. I want to remove only the engine. So far all accesories are off, intake manifold, distributor, radiator ect... Other than just needing to undo the motor mount bolts on both sides and exhaust manifolds, how many bolts am I needing to unbolt from the block to the bell housing and do I need to undo any bolts on the flex plate to the torque converter or can I just pull out the engine with the flex plate and torque converter on?? Sorry but I am a complete newb to the older domestic rigs. I just really want to see this old beast running again. Thank you guys in advance.
Old Aug 3, 2010 | 1:58 AM
2wd-K5's Avatar
there are 6 bolts on the bellhousine, 2 on each side, and 1 more on each side halfway up. there are 3 bolts on the flexplate some have nuts and are easy, and some have just bolts and you need to hold the flexplate i use a long strong screwdriver wedged between the tourque converter in 1 of the flexplate holes to stop the engine from turning (crude as hell, i know but it works) and not which way the engine mount bolts go through, they are faced opposite, and it is like that so they dont back off from the tourque or the engine.
hope this helps you
Old Aug 5, 2010 | 12:06 AM
Thumbs up
hope this helps you
Thank you for the info. I'm gona try first thing in the morning as long I dont get ambushed by the ants again.
macruadhi
May 25, 2011 12:29 PM
twotoneguy
Jan 16, 2011 8:34 PM
lt1 munster
Jun 19, 2010 3:31 PM
jensenracing77@yahoo.com
Jan 11, 2010 4:03 AM
