carb problem
Old Feb 24, 2019 | 3:17 PM
Mikael Styleline's Avatar
Default carb problem
Hello I have a question. It seems to be a 1 bbl carburetor made in Asia (rochester copy?) for a 250 inline six on my 194 engine. It has very high fuel consumption. it is possible to change the nozzle / jet so that everything harmonizes, or should I change the carburetor
Old Feb 24, 2019 | 7:04 PM
kevinkpk's Avatar
That would probably depend on the altitude, but yes if that is the case.
Old Feb 25, 2019 | 4:44 AM
Thumbs up carb problem
Thank you for your replay. Do you have any tip for size on the main jet
/Mikael
Old Feb 25, 2019 | 6:50 AM
kevinkpk's Avatar
Search nthe web with the carb number. There should be a list of specifications.
Old Feb 25, 2019 | 6:53 AM
To determine if you have the correct jets in your carburetor, operate your vehicle for 20 minutes at sustained speeds. Stop and pull a plug. Gray - Good, Black - move down one jet size, White - move up one jet size. Do it all over again until you get a gray plug.=left
https://www.carburetor-parts.com/B-B...es_ep_524.html
Old Feb 25, 2019 | 2:46 PM
Thumbs up
Thanks, I took out the main jet, it was 100! if I change to 0.60, do I also have to buy a new metering rod? Or can i use the same?
/Mikael
Old Feb 25, 2019 | 3:00 PM
kevinkpk's Avatar
Metering rods need to be matched to the jet. Not only will you realize better gas mileage, but much improved performance.
