CHEVY 87-95 350 TORQUE SPECS
Old Jul 27, 2006 | 9:07 AM
atlbigboi's Avatar
Default CHEVY 87-95 350 TORQUE SPECS
I AM PLANNING TO PUT A 87-95 350 IN 82 MONTE,AND WAS WONDERING IF ANYONE KNEW THE TORQUE SPECS ON THE ENGINE OR LINKS THAT MIGHT LEAD TO THE INFO.THANKS ALOT GUYS
Old Mar 20, 2008 | 6:58 PM
VABowtie82's Avatar
Default -
Old Mar 21, 2008 | 9:10 PM
TransAm Man's Avatar
Default RE: -
Go to a dealer and ask if you can use thier Alldata system, they will probably let you use it.
Old Mar 27, 2008 | 7:43 PM
old dog's Avatar
Default RE: -
i assume your talking about engine spec's 88-95 5.7 cylinder head 65 ft lb main bearing bolts ,outerbolts #2,3,4 70 ft lb,all other 80 ft lb's.connecting rod bolts 45 ft lb's.harmonic ballancer 70 ft lb . flywheel 1988-91 60 ft lb 1992-95 70 ft lb.intake manifold 1988-95 35 ft lb. this from chilton's manual #8055 1988-1996 years chevy gmc full size truck manual can get it from o'reileys
H07
Apr 26, 2025 3:34 PM
SyberTiger
Jun 30, 2014 9:03 AM
mcphck
Aug 21, 2012 5:37 PM
typhoon4x4
Camaro
Nov 3, 2007 3:35 PM
atlbigboi
Jul 27, 2006 9:07 AM
